Johnson Colt Rebuild?
dthrckt
I've been skimming over posts that mention the Johnson Colt. I have a 1986 JCOCDR and absolutely love that little motor.
I ran across the following post. The user is apparently infrequently or totally inactive, so I'm wondering if someone can tell me where I could get the parts required to do this, and who might do the cylinder borings (or would I have to buy a ream)?
thanks!
QUOTE:
Re: Johnson Colt 2 hp Outboard
I just rebuilt one of these little engines this past weekend. It was very easy and took only about 3 hours from start to finish to completly dissasemble, bore the cylinder, install new piston, rings, bearings & gaskets. Cost about $100 including the cylinder overbore. I bored it over .030". So I figure I was getting 1.25 HP out of the engine before, I'm probably now getting all of 1.30 hp. It fired right up and runs like a top. I'd suggest putting a new top end in yours. Let me know if you have questions.
Daviet
Re: Johnson Colt Rebuild?
Quick check of the parts breakdown shows parts still available from Johnson. Go to their website and look up your engine to see parts breakdown.
I would check the cylinder to see if it really needs to be bored, might just need to hone it and install new rings.
dthrckt
thanks, now why didn't i think of that - I figured you could get original replacements but I just checked and saw the .30 oversize piston, too. Still not sure how you ream for it to fit though.
I don't need to do either yet, but the previous owner overheated it more than once. This winter I'll do at least the gaskets. Then I'll get a good assessment of the condition.
dregsfan
You can order many OMC parts through any NAPA store. Most prices will be lower than OMC.
I have a 1980 2HP. I need to rebuild the carb over the winter.
dthrckt
thanks for the tip. i've got several old OMCs, including the 86 Colt (1.2hp) and a 77 2hp. Did both those carbs this summer. You probably already know, but they're really easy to work on.
