I have a 1996 Johnson 48 special and I need to know about what the compression should be? Do I have to warm up the motor first then check compression? The reason I'm checking is it seems that I don't have as much power as I used to have, the boat won't even plane with 3 people in the boat and I checked for water in the boat and left the lower plugs out and tilted up for a few weeks.I replaced the fuel pumps and it seems to run fine, sounds like it is running wide open and I checked the prop. all is good.
5string in NC
5string in NC
