Re: Johnson Electric Start Motor 25 Hp
this is for mobiouss there is no timing setting persay on your motor.you have a flywheel mag. <br />Points are in flywheel usually can be adjusted through hole in flywheel.Adjust to .020" when adjusted right timing is also correct. Spark plugs .030" Plugs old number J4J new J4C I think.If your going to be fooling with your motor<br />you really need a manual There is a tab above or<br />Amazon.com,Barnes and Noble,EBAY etc. etc.<br /> Spike
