lyncraft_mechanic
- Joined
- Jun 22, 2007
- 233
I have a 28spl johnson outboard model number J28eslcuc with an electrical problem, when i turn the ignition nothing happens and here is what i did so far-
checked the battery- 12.54 volts
replaced the 20amp fuse located next to the starter solenoid- it was bad
tested the starter- its good
replaced the starter solenoid
checked for broken/burned wires- nothing
I have power at the ignition switch
bypassed the neutral saftey switch
eliminated the laynard kill switch
what else can i possibly do, could it be a bad igniton switch? is there some unknown saftey switch located on the motor?, if there is i can't find one! any suggestion would be greatly appreciated, thanks
