What is the displacement of my 1960 40 HP Lark Evinrude Model 35520?<br />I have a 1959 Johnson 35 HP and it clearly says 40.5 CID. The 40 appears the same, but what can you tell from the outside. It has no indication of displacement. The real question is: what's the difference? Is this another case of different Carburators? or valving (porting)? or exhaust? for the same bore/stroke? I found info (within this forum) stating the 33 HP is also 40.5 CID. And, as if you couldn't guess, my 40 powerhed is fine but the rest is shot,(parts donor) so I might swap it into the Johnson for the addded HP. Somebody tell me if I'm wasting my time, and should just swap the carb or something.<br />The discussion earlier about HP v. Displacement was entertaining, but I don't feel the need to revisit that here!
<br />Thanks a bunch for your time and interest.
