first off, i have a 1970 johnson 18 hp outboard. i just bought this thing for dirt cheep. the guy i bought it from said he did a lot of work to it. like new water pump, cleaned carb, new plugs.... this things looks really clean and i was thrilled to get it. anyways, he told me that it had an idle problem. he said that it problay was the fuel pump cause he could pump the fuel bulb and it was stay running. anyways, i got it home and ran it, like he said it didnt want to idle but higher rpm seemed good. top end seemed a little sluggish, like it was bogging down. it also seemed to smoke a lot even know it was in a large buckey - half a 55 gallon plastic drum. well, i put it on my 14 ft aluminum jon boat today, i was a little worried about it being over powering and too heavy. this boat is only 48" wide and light as a feather. well i took off and it seem to plan off. it didnt exactly blister across the water, it pretty much just ran above plan. i guess my question is, where should i start? i know it doesnt idle well, and i also know it boggs down up top. could this be cause by the carb?? it seems to run really well, fires right up other then idle and top end. just seemed like it didnt have any guts once opened up. sorry for the long post. any suggestions would be great. bye the way, the serial number is 18002c-e09822 i dont know the model number cause the hood is missing, which if anyone knows of one or where to find one it would be great.
