RoughFishAssassins
- Joined
- May 9, 2010
- 103
I purchased a 1974 Johnson 85hp for a parts motor, it had a working tilt system on it, but it is unlike any that I can find for these motors. I took it off the 85 and installed it onto my 1977 115hp. For the most part the unit does what it is supposed to do, raise and lower the motor. But I found that when running in shallower water and wanting to tilt the motor up some, it would not hold against the push of the motor. in othere words when I tilted it to a comfortable level and starter forward with the throttle, the motor would push the tilt back down. Is this just the way the system is or are there possibly seals that are out of either the tilt motor of the tilt ram? and which could it be? We are occasionally running in shallower water and cant have the outboard all the way down for the risk of damage. When in this situation we are always aware of the water inlet to make sure the motor is properly cooling. I just need to know what I can do to keep the motor at a certain hight with just the tilt system. I have attached photos but they are kinda hard to see everything due to a recent fresh paint job.
Most every tilt system I have found specs or pics of are a twin cylinder lift on the outside of the housing, never a single ram under the housing like this. Any help you guys can give me is greatly appreciated!
