Johnson-Evinrude
oldcatamount
Re: Johnson-Evinrude
Wolfgang Ficht designed a fuel injection system for OMC and they called it the "Ficht"
Chris1956
FICHT (and e-TEC) motors use a high pressure fuel pump to force gasoline only, into the combustion chamber of each cylinder, after all ports are closed on the piston upstroke. Air and 2 cycle Direct Injection oil still traverse the crankcase in the traditional fashion of ordinary two cycle motors , although the oil delivery systems is more sophisticated, and use less oil. The effect is that only air and some oil are required to sweep out combustion gasses from the previous power stroke. Since the gasoline is injected after the ports are closed, raw gasoline (and it's nasty hydrocarbon pollutants) is burned more completely, and not discharged into the exhaust.
The net effect is a much lower level of pollutants from the motor, which rivals a 4 cycle motor's pollutants
Haffiman
It was not designed specially for OMC. It is quite an 'old' patent and was even tested out long before OMC came into the picture by among others Ford Europe which finally gave up. That is when OMC came into the picture.
