Bream Killer
- Joined
- May 1, 2020
- 37
I found one of these at a yard sale a few years ago for $10.00. It looked like it had been used maybe one or two times and was clean as a pin inside and out. I hadn't used the boat all this time and you guys had been helping me thru the re-build of the 9.5 Johnson. The motor is running OK except every now and then its starved for fuel and a quick pump of the bulb and it's back in business. The issue is it's intermittent. I did a complete rebuild of the carb and put a new fuel pump on it. On the new fuel pump it was thicker than the old one. I had to get longer screws to mount it. It was like it had an extra section in it.
Thinking it could be the gas tank vent I cracked the fuel tank top and it still did it one time. I haven't been on the open water yet, just running in the tank. Is there anything to be concerned about this old tank? It seems to be in great working order, nice and tight, no leaks.
