trickster734
- Joined
- May 16, 2003
- 20
I have a johnson gt100, engine will run and idle while I have the muff installed, however when placed in barrel it will start and will only run if throttle is nearly wide open and even then it runs slow and will "catch up" to the throttle position and rpm's will climb. It will not idle like it does on the muffs and will die out. carbs have been cleaned and it is getting gas. Pls help don't know where to start, idle settings, timing something????
