Johnson Hydro Electric shift lower unit question
rsamsel
I have a 1972 50th anniversary hydro electric shift. Can anyone confirm if the lower unit in this ad will fit my application?
I included a pic of my motor to help confirm.
Rob
The 3 cylinder and 4 cylinder units do NOT fit the 2 cylinder electric shift units !!------What is wrong with your unit ???
You need to look for a 1971 or 1972 electric shift from a 2 cylinder 50 HP they are the only 2 models that will work for you
rsamsel
I might have confused the situation. I have a 65 hp three cylinder from 1972 model is 65esl 72. visually mine looks the same as the one on craigslist.
rsamsel
I am looking at the copper colored one. not the black one that is for a v4. I have the 3 cyl
The 3 cylinder lower unit will fit a 1972 3 cylinder.-----The 68 to 72 units on the 3 cylinder are not all the same internally but they will interchange.-----I am not going to go into the details of the internal difference today.
rsamsel
My setup runs and drives perfectly and I use it several times a week but reverse is out. I am sure its out mechanically tho. I can hear it try to get into reverse but it just grinds. I have gotten shavings out of the lower (prob the reverse gear I assume) Other than reverse it is 100% usable.
rsamsel
So the official word is no its not the same, but yes it will work? Just confirming
