Re: Johnson Hydro-electric shift question
WELL !!!! Now that we know the finer details......<br /> In an electric shift system, when the control box is put into forward, 12 volts energizes the forward shift hub. So check the green wire to see that it's getting the 12 volts. When the control box is in neutral, no power goes to either the green or blue wire, In reverse, 12 volts goes only to the blue wire down to the exhust/lower unit. When you check for this voltage, remember that the integrity of the gear oil (premium blend only) must not be contaminated by water, dirt, etc... <br />The system works like this. All the gears rotate all the time.. Actually, the gears each turn a large "hub", that's slightly knerled, the shift spring is connected to a coil and when activated by the 12 volts, is magnatised and collapses onto the outer portion of the hub. It "grabs" the hub and locks the gear into/onto the prop shaft. Remove the 12 volts, the spring releases it's tension and unbinds the hub. Often the end of the spring breaks, so no action is noted. Often spring breakage is caused by shifting at too high an idle speed. Or manfunctioning shift switch in the cintrol box....Hope this helps !!!
