CooperClaude
- Joined
- May 20, 2007
- 5
I have only worked on one Johnson/Evinrude, a 3 hp. I have a Johnson V-4 labeled 85ESL 756 and serial # J4314723. The motor starts only after an injection of ether or gas/oil sprayed directly in carbs. Choke works, just won't start any other way. Motor has sat up for a long time. After cranking I've let it run on hose at idle for as long as 15 minutes. Question, water comes out two small holes in back and thru propellor. Is this a normal discharge ? I'm used to Mercs. Any help is appreciated.
