I have a 78 model 140 hp Johnson outboard. When I raise the fast idle lever for initial startup and the return the lever to operating position it does not return to the rubber stop on the linkage arm which in turn causes me to idle to high. If I go under to cowl I can manually push the arm back where it should be, but that's is aggravating to have to do while on the water. Any suggestions. Thanks and God Bless
