johnson info please
pinto 21629
does any one have part numbers for my 1960 rds-22 super sea horse 40hp i need part numbers for head gasket.head cover gasket.water pump impeller . thermostat.i dont need the carb one and i dont need the one for the o rings for the valves in the compression relif valve o and do i need ant when i put the lower unit back on after i put the impeller back in its still spraying out water but i dont know when it was changed last any info would help
