johnson j225txccr 1988
Good Day
I just replaced the power pack cdi blue type and after starting it up
it runs at a very high idle over 2000 rpm and it is back fireing and puffing smoke from the back of number 3 carb sometimes the motor will stall.
the back fireing is so bad fire will shoot out of carb number 3. and it will not idle under 2000 rpm
I changed plugs but it did no good.
here what i have done to the motor in the past few weeks
replaced the stator CDI timer base CDI voltage rectifier OMC
engine harness CDI all had bad wires
also i serviced the carbs
I spent some big bucks on this motor and still it sounds like more bucks
to get it running right any ideals on what to do next thanks for any help
Daviet
Re: johnson j225txccr 1988
What was the orignal problem, why did you replace the power pack?
no spark and wires where bad and green from salt water
i use boat for offshore fishing
