Johnson J25RLEDA Trouble
Does this engine contain a carborator intake filter, it seems when we are driving it that dirt is getting sucked into the engine.
ezeke
Re: Johnson J25RLEDA Trouble
You should find a screen on the fuel pump under the cover and a screen at the bottom of the fuel tank on the pickup. No filter came with the motor, but you need one, preferably the water separator type.
F_R
You mean an air filter? No.
Why do you feel it is sucking up dirt? Are you kicking up a lot of dust from the lakes where you live? Or are you running it on a construction barge?
It is at high RPM's when the motor is running, seems like it is cutting in and out, maybe a misfire?????
F_R
You have tried a new set of spark plugs, right?
