Re: Johnson kicks into gear when turned off????
Schematic's schematic is a big help on visualizing the circuits.<br /><br />Your motor has a hydraulically shifted gearcase that is activated by electrical solenoid valves. With no power or hydraulic pressure, it is spring loaded into fwd. gear. When you start the motor in neutral, 12v goes to the green shift wire to close a valve and build up pressure to move the clutch dog away from fwd gear, putting it in neutral. When you turn the key off, the green wire loses 12v and the solenoid retracts and the clutch dog "bangs" into fwd.<br /><br />The stator generates AC current that is changed to DC battery charging current by the rectifier assy. The diode assembly hanging there, changes AC current to 12v DC to keep the green neutral wire energized while the flywheel is still spinning down. If the rectifier is shorted, the stator not generating, or the diode assembly is faulty, the green neutral wire will not get 12v after the key is turned off. A broken or corroded connection or wire can do the same thing.<br /><br />I hope this explains how the system works.
