a bit from thru prop exhaust. 1995 J50TLEOD 50 hp. Scared me when I noticed it. Oil is jet black and sorta thick. I immediately pulled LU fill and drain plugs and checked it. It was fine.. I had just put fresh lube in at the onset of freezing weather. The only thing I can *guess* is I've been using 2+4 carbon guard and a bit of Sea-Foam on each tank of fuel as maintenance after de-carb back in late summer/early fall and it has broken loose "gunk" in the exhaust system. Compression is 148 on both cylinder's. Any where else this could be coming from?
