Two weeks ago I posted a message about a possible oil leak in my lower unit. I removed the LU and found oil deposits around the left side of the water pump. No oil seen in the Pump housing. Lots of oil deposits in the exhaust shaft out port. LU is functioning fine, and the oil drained did not have signs of water in it. The problem developed on dry dock. I plan to have it bench tested for pressure, but want to know if it just might require a new seal. I've seen seal kits available for LUs. Thanks.
