Johnson Motor on a Winner Hull - need main wiring harness and throttle/shifter control
Jasper Burt
I need a Main Wiring Harness from the motor (1976 Johnson 80HP) to the key switch on the dashboard. Also the key switch panel. I also need the full throttle/shifter mechanism and cable from the steering wheel to the motor.
Don't care if they are originals. I see a few available on EBay and Amazon. Just not sure what to look for.
I do not believe they marketed an 80 HP in 1976.---And on a 76 everything would be in the control box !------You need to post a model # or pictures.
Jasper Burt
Here are the model number plates for the hull and the motor. The year could be wrong?
Jasper Burt
Is the hull supposed to be a ballast? I mean Is the space beneath the floor supposed to be airtight between the floor and the hull? (The floor has some cracks in it)
jbcurt00
Keep this topic about the motor and controls
Start a new topic about the boat hull in the Restoration forum.
No, not meant for ballast
clemsonfor
CDI had wire harness available for certain motors, not sure if they have something for that age motor. Also keep in mind that anything used may be almost as bad as yours. The insulation they used on those era boats seemed to wear pretty badly through the years. Like even ones that weren't really in the sun and weather.
