old yeller
- Joined
- Jan 24, 2003
- 6
I have a 1972,Johnson 125 H.P. outboard with no spark to the plugs.Is it possible for a bad rectifier to cause this problem?I have a Clymer shop manual and have performed tests on all systems.The following are the results of these tests.The rectifier is no good. The sensor tested ok. the pulse pack input is ok, plus its brand new. the pulse pack output is no good. the coil is brand new, but of course its not getting anything from the pulse pack. the clipper circut tests no good. what im asking is the system appears to run on direct current, with the rectifier changing alternating current to direct current. Is it possible that the pulse pack is receiving only alternating current and it sences that the ignition system is off? any help would be greately appreciated as I'm confused.I'm about to pull the little remaining hair that I have left out. Thanks in advance for the help
