Johnson ocean runner 115 balance tubes
Boblester40
hi..
Just finishing off a rebuild of a 1996 ocean runner 60 degree which had blown a piston , the previous owner had removed some parts before i got to it and would like to know where the balance tubes from the throttle body's should go , i have guessed that one should go to the nipple on the air box and the other should go to the lower crankcase drain ? also does one of the pipes from the vapor pump assembly poke into the air box via the hole at the top corner ?
Any help is much appreciated
regards
bob
