I just put a new seal in the power trim cap. It was leaking from there prior. I reassembled the piston assembly and rod and then put it back in the cylinder and screwed the cap back on. I made sure the piston rod was fully extended and then filled with as much fluid as it would hold through the fill hole. I worked it up and down a few times (no problems other than being a bit jerky) and now it is stuck in the up position. The relays were replaced and are good, so it's not them. It's almost as if there is a sort of vacuum on the piston keeping it from going down. Is this possible? Any ideas how to get it to work again?
By there if it matters, it is a 1992 model #j40ttelnj 40 hp.
