Re: johnson prop
We need to know more details to make a correct prop selection.
Present prop size ,probably under the prop nut.
Need wide open throttle rpm and speed with a light load.
Now is the time to be sure you have the right prop but if your happy with the performance just use the numbers under the prop nut.We can tell you what they mean.
if any confusion.
