AlfrmVaBeach
- Joined
- Jul 6, 2006
- 9
Fired up my new to me QD-11 tonight, only to have it run out of fuel. For some reason there's a blockage in the fuel connection at the motor. This uses the two line fuel hose, pumps up firm but won't push fuel past the connecter, lines from there to the carb are clear.
I removed the fuel connecter and can blow through it from the back just fine on both fuel and air lines. If I blow from the front, fine on the air barb, starts out OK on the fuel barb but then stops.
Assume there's some sort of check valve in the fuel barb, is there any way to pull these apart and check? The parts manual lists Part # 375589 for the barb, anyone have any idea where to find one?
