Ok, I am in the process of installing an lanyard style ignition kill switch, so I removed the flywheel with no trouble since it was just removed by the previous owner to install coils. I noticed the point sets and mag plate were a bit oily. One of the points was adjusted a little tight, so I fixed that and removed the plate to drill it for the switch wires.
At this point I noticed the previous owner did not install two of the four screws that hold the mag plate on. The two that are missing are the long ones that go through the coils. Is this a big deal?
Next I noticed that the "ring" that the mag plate screws to, to attach to the powerhead is loose and spins around beneath another bracket that retains it. Is it ok for this "ring" to be loose?
This ring and the area under the mag plate in general is somewhat wet and oily. I read that there is some type of upper seal here. Does this oilyness mean that this seal is bad? If so, is it easy to change?
One last question, I cleaned up the points and mag plate with Brakclean. What do I put the tune up grease on - the felt wiper on the points set or the cam itself?
Thanks for all of your input!
Mike
Grand Rapids, MI
Mike
Grand Rapids, MI
