Johnson RDE-16 stator cables
1aviationnut
Hi,
Does anyone know how the two throttle/stator cables hook
to the underside of the stator plate on a Johnson RDE-16 1954?
The cables have a ball in each end but I can't see how they clamp
to anything.
Also looking for a long shaft drive shaft for same motor, have the
tower extension but no drive-shaft or shift-shaft extender. Got a extra
set of drive shaft gears and foot housing if anyone needs it.
Thanks
J. White
F_R
Re: Johnson RDE-16 stator cables
It has been too many years for my brain to recollect, but the cables track in a "pulley" on the bottom of the armature plate. The ball ends simply slip into or through a notch or hole at the ends of the pulley. Tension on the cables is maintained by a spring between them. Take a close look and it should be clear.
