Thanks for all the help on my johnson 225 oceanrunner,<br /><br />The problem turned out to be the powerpack,still havnt figured out the frequent alarm soundings,but the engine runs fine so what the heck.<br /><br />Cheers
Hello, Borneoman.<br /><br />I wouldn't use that engine until you find and correct the reason for the alarms.<br /><br />If the alarms are working correctly there is something wrong that will destroy your engine if not corrected.<br /><br />If a bad sensor is causing the alarms you will not have warning if something does go wrong.<br /><br />Either way, using the engine and ignoring the alarms is doom to you engine.<br /><br />Good luck.
