Johnson Runs ....... Badly
EJ3
I think I know what the problem is, but looking to get opinions/confirmation from people better at this stuff than me!!!:D
Here's what happens...
I launch the boat and warm up the motor. Idle speed for a few minutes until I am allowed to go WOT. But when I go WOT I only get about 3000 rpms. Once on each trip, which is only 2 times now, it will get up to 5500 rpms for about 30-45 seconds then goes back to only 3000 rpms. This happens in the begining of the trip when the motor has not been running a any length of time. It idles with no problem. I think the problem is the coil on the top cylinder. Here's why... The motor ran the same way when a part of the carb broke and was not working properly on the same cylinder. I have fixed the carb problem. I do have new spark plugs. In the begining stages of fixing the motor I do recall having a problem getting the top spark plug to show me a spark when I had it out of the motor.
Just FYI: On the water I tried squeezing the primer ball and the rpms did not pick up. I try bumping the choke and the motor starts to die, normal I believe.
Like I said, I think it is the coil on the top cylinder. Can someone please agree or point me in the right direction for fixing, thanks!
I have priced the coil and it is not too bad. Is the coil on of those things that if 1 goes the other is soon to follow? If the problem is the coil should I just go ahead and replcae both?
1977 55hp Johnson
tashasdaddy
Re: Johnson Runs ....... Badly
what motor? make, hp, year or model#. could be several things. coil not firing, clogged high speed jet. also check the compression on all cylinders and post results. bad carb with no fuel going to cylinder could have damaged cylinder. are you sure it is not running hot. just because you have tale tell stream, doesn't mean the tstat is opening.
EJ3
I edited the post to place the motor description in it, probably while you were typing (tasha)!!
The model number is 55EL77D.
I have cleaned the carbs and did the carb kit.
I have done a compression check when I first fired it up and everything was fine, 130 on each. Now that it has ran a few times, and more than just idle spped/rpms, I will re-check and re-post results.
tashasdaddy
completely swap the postion of the suspect coil, with one of the other ones. if the spark problem follow the coil, replace. if not then we look at the power pack.
