steamking123
- Joined
- Aug 8, 2009
- 42
Recently my 61 johnson 75 sea horse wont go in forward gear. since I have had the motor occasionally it will pop out of gear while going forward. now its gotten much worse and it wont go into forward gear. it goes into reverse with ease.
I disconnected to linkage from the remote shifter and put into forward. this helps but only goes into gear about half the time and most the time is sounds like it is trying to shift but wont go in all the way, aka a grinding noise.
Reading other posts, it sounds like its bad news. something to do with a dog.
I also have a 59 Evinrude 50 parts motor. they are pretty much identical with a a few changes. Can I use parts from this motor to fix the johnson 75.
Derek
Derek
