I'm taking on a little water in the lower unit. I put some ear muffs(square, works great when you take off the little slow speed inlet) on it yesterday. After that, I checked again and oil looks good. Could the leak be coming from the prop seal. I read somewhere that I can take the lower unit off without dropping the lower unit. ie turn upside down and take off bolts. Is this true? Could I change prop seals like that?
