Johnson Seahorse Help Needed
markkay19
Could anyone please tell me the correct spark plugs for a Johnson Seahorse 4 HP engine model no. 4BR71D, Serial No. B11288 in an NGK type if possible, plus gap size, also point settings and fuel mixture and year.<br /><br />Many thanks<br /><br />Markkay19
Bear
Re: Johnson Seahorse Help Needed
4BR71 4 hp 1971<br />4 hp 1969-1976 NGK B6S gap 0,8 mm<br /><br />Fuel/oil mix 50:1
markkay19
thanks very much for your help,do you know the points gap setting thanks.
markkay19
thanks very much for your help . do you know the points gap setting .thanks
nwcove
avoid the ngk plugs if at all possible. i do believe the correct plugs are champion, j6c or j4j
