Re: johnson seahorse
Those are nice little motors. They're basically an upgraded version of the old light twins and Jw's. Basically the same design, but quite a bit huskier. You'll want to run 24:1 mix in that. Some will say 50:1, but there are no needle bearings in those motors at all and they are a friction type engine. Unfortunately, I have the same motor in my shed which I had to install a crank and rod kit for a guy, because of a lean fuel mixture.
