Re: Johnson seahorse18 hp
Sure tj, settin up controls is easy. Just check ebay and/or aomci for vintage OMC controls and you'll find all kinds of stuff. You'll need two special fittings for the end of each cable, one for the throttle, one for the shifter. They're readily available online. You'll then need two cables. You can get new ones right here at iboats. They're identical except for the fitting you put on the end and each attach to the control box in the same manner. As for steering, there are lots of different types of set ups. You can go with the old school "cable and pulley" style, which is a simple mechanical steering mechanism. You can also get a modern rotary system too. Do a search here in the forums and you'll find tons of threads. It's not hard hooking up the remote controls, but it may cost a couple hundred bucks depending on where you get your parts.
