Re: Johnson starter stuck up on flywheel
If you are referring to an electric starter, and you mean the pinion gets stuck engaged to the flywheel, it probably just needs to be oiled. They do periodically.<br />Just wash the grease off with wd-40 or what-have-you and oil the screw shaped thing the pinion rides on with a light machine oil.<br />Otherwise, please post model, or hp and year.
