johnson starting trouble
firefox
i have a johnson 60 electric super seahorse don't know year it's green and white the motor will turn over but won't stay running any ideas
tashasdaddy
Re: johnson starting trouble
look between the transom mount clamps for a plate with the model #. i can think of several things, dirty carb, stuck float needle, points,coils, condensers. tell me more of what you have done, history on the motor, has it been asleep for a while, and you are reawakening.
firefox
the boat has been asleep for 10 years i've cleaned the carb pressurized the fuel line with it disconnected from the carb fuel came out hook it up tried to start didn't start put some fuel directly into carb it ran for a minute then died checked to see if gas is spurting into carb don't see any then we disconnected fuel line from carb it was pressurized i think the floats are stuck and not letting gas into carb model # vxl-13a
firefox
any other ideas the carburator has 2 adjustments across from each other i believe the motor is a 1967 60hp electric super seahorse
tashasdaddy
first don't beleive it is a 67. know it is thats why i ask for the model number. WHAT"S THE NUMBER? here's a thread on carb adjustments.
http://forums.iboats.com/showthread.php?t=167352
have you checked compression, what are the numbers? spark? jump 3/8 to 1/2 inch on all cylinders.
there are 3 basics, for this engine to run and they all have to be right.
1/ proper compression 2/ proper spark & timing 3/ proper air,fuel, oil delivery.
