Johnson Super Sea Horse - yr needed - HELP
jonny834
I have a Johnson Super Sea Horse 60HP engine. Model No VXL 12R<br />Serial No B1802<br /><br />I need to know the year of manufacture and then a manual to help me maintain this engine. Can anyone help me with this??<br /><br />Many thanks<br />Jonny
Paul Moir
Re: Johnson Super Sea Horse - yr needed - HELP
Sure thing Jonny. Welcome to Iboats first though.<br /><br />Johnson VXL-12R<br />Year: 1966<br />HP: 60<br />WOT RPMS: 4500 (4000-5000)<br />Displacement: 70.7 cu.in. = 1158.6 ccm<br />Cylinder configuration: V-4<br />Weight: 225 lbs. = 102.1 Kg<br />Gearcase ratio: 20:23<br />Fuel/Oil mix: 50:1 87 (91 RON) octane gas to TCW-3 rated outboard oil. IE, 20ml per litre of gas.<br />Spark plugs: Champion J6C (was J6J) gapped at .030"<br />Picture<br />From the Old OMC Site <br /><br />Iboats sells an aftermarket service manual for your engine. But a reprint of the original factory manual is superior as it is specific to your particulair engine. Reprints are available from the following places:<br />TheOutboardWizard<br />Mastertech<br />Marine Engine<br />Ken Cook
jonny834
Mr Moir you are amazing...I ask an obscure question about something from the last century and 12 minutes later you come up with the answer plus... Quite brilliant.. <br /><br />Now, about next weeks lottery numbers????
