Re: Johnson/suzuki 140 prop
Yes, I understand, and I must say that sounds alot like my Raker performed once I got my engine heigth dialed in.<br />By your description, the Trophy is doing exactly what it was intended to do...lift the bow at higher speeds.<br />Slight positive trim at cruise IS normal, and what you are explaining about venting by trimming farther at cruise, leads me to think you have found an efficient set-up as you are.<br />Gaining more IS possible, but it's gonna require an engine lift, and yet another prop, or tweaking the one you have by adding a bit more cup.<br />Over-all it sounds like you are finding good performance with the current set-up...the decission to go farther is up to you and your wallet.<br />The reason I asked about the Trophy being stock, is I wanted to make sure it hadn't been worked for higher RPM....most times it's best to ADD cup, or pitch to a wheel that turns a little fast, rather than remove cup from one that needs RPM(Less efficient).
