Johnson tachometer problem
teflonharry
Hi! My tachometer works fine up to ~2500 rpm.<br /><br />Does anyone know what the problem can be?<br /><br />I think the tach is connected to the rectifier is that right? Johnson 110 -86<br /><br />/Harry
Hooty
Re: Johnson tachometer problem
Thaz right Harry. The gray sender wire from the tach should connect to either the yellow or gray & yellow wire at the rectifier. Is the rectifier okay? Is the battery charging?<br /><br />c/6<br />Hooty
teflonharry
No! I found out that the rectifier is probably not working. It does not charge the battery and the tach is not working allright and I get strange ohm readings when testing.
Hooty
If the rectifier is bad, the tach won't work.<br /><br />c/6<br />Hooty
