Johnson Td 20 lower unit
steven859
I have a 1946 johnson td 20 outboard.While atempting to remove the lower unit I busted the heads off 2 of the 4 screws that hold it to the upper unit.What should I do to try to fix this?<br />thanks :confused:
Hooty
Re: Johnson Td 20 lower unit
The busted bolts will have to be removed. You can probably do it yourself but the easy way is to take it to a machine shop and let them deal with it. <br /><br />c/6<br />Hooty
