Underblog
- Joined
- Nov 27, 2011
- 47
I have an older (1980's vintage) Johnson 25hp on my pontoon boat, with Johnson controls attached. Recently, the throttle control stopped working. It appears as though the large cam which pushes open the throttle mechanism has become detached from whatever cable is supposed to operate it. What should I be looking for under the cover? A friend and I did not see any loose cable floating around; is it possible that it could have been drawn back inside the housing out of sight? Boat shifts gears, starts, and can idle forward and backward. Only the throttle opening mechanism appears to be out of whack. All clues or suggestions welcome.
Eric
Burntside Lake, Ely MN
Eric
