Re: johnson tilt and trim stopped working
Try lightly tapping the trim motor to see if a brush is stuck if that doesn't work follow the wires up into the motor there should be a connector between trim motor and the relay box; take it apart and see if you have a bad connection there I spray battery cleaner in that connection on my motor. Good luck
