Chum Slick
- Joined
- Aug 7, 2001
- 116
1980 115 hp Johnson: Do I have to remove engine from boat to replace the tilt/trim actuator (motor)? The motor will actuate while tapping on top of motor with switch engaged which leads me to believe loose contacts, corrosion on contacts, or worn brushes. I removed top cover of actuator and cleaned brushes and checked for corrosion on contacts, replaced actuator cover and still have same problem.
