dwco5051
- Joined
- Sep 14, 2008
- 2,452
It worked when put away in the Fall, went to raise motor this Spring and it no go. Took apart to check for a stuck brush since it did not have continuity and found the connection to the brush from the spade terminal in the bottom of the picture is open. It the little black box the connection a one shot fuse or maybe some sort of thermal overload? Thinking of just soldering a jumper across it and putting an inline fuse in one of the feed wires. Any suggestions.
