I have a 1991 Johnson 12v. trolling motor. It have two plastic gears, that make it turn, when you press the foot peddle.The round gear in the center of the shaft is busted. I bought a new gear and bearing, but I can't get the broken gear off
!I loosend the two allen screws on the lower end of the shaft, to allow it to slide up.Then I removed the allen screws from the broken gear in the head.It looks like there is a pin driven through the gear that is holding it in. What should I do now?
I tried using a punch, to knock the pin out. That didn't work either.There is also some wires going through the center of the broken gear.
