bob johnson
- Joined
- Feb 25, 2009
- 4,306
So i bought some seals for my lower unit along with the water pumps...figured Id try to replace as much wear items as i could .( with out a total rebuild) so im replacing the seals for the driveshaft, and the seal for the prop shaft and the seal for the shift rod, and last night i took the carrier out of the LU and see 2 large O-Rings....one on each end...and thought...heck i should replace them, but now the weekend is here...no time to order parts. the local guy doesnt have them in stock. so im looking at sierra parts # and it shows an O-Ring that also is used as the Cylinder head seal!.... i saw this on a third site as well..... is that right?? the parts diagram actually has a seperate part # for each O-Ring.... but the Sierra and several other aftermarket parts houses show the same part # for both the seal in the Lower Unit and the seal around the combustion chamber in the head....... I think i can go find the sierra locally... plus I think i have some O-Rings for my other motor rebuild project..but they are home and Im looking to stop and check for availability on the way home in a few minutes
