snookhansel
- Joined
- Jun 3, 2009
- 5
Hi i am new to the forum and new to boating also so be patient with my dumb questions. I recently became the owner of a 20' bass boat it has a 200hp venom. I was told by my local marine not to trust the ioling system so i premixed my fuel. I started the engine in my driveway using the water hose clamp on thing, see told you i was new to boating. The motor idled and ran fine. when i took it out i got it to rev up and run down the water twice. both times once the rpm's were up it ran fine. After 5 hours on the water i gave up. The motor would idle then act like it would run out of gas. At times i could get it to idle, but when i put it in gear it would flutter and die. When i brought it home i checked it in the driveway and it ran fine again. I dont know why it will not run when i put it in the water. If anyone can help i can give more information to the things i tried. It almost seemed like after the exhaust was lowered under the water the thing just didnt want to run.
