Johnson vro 200hp question
Cadones
i recently purchesd a new boat. the boat came with a johnson vro 200hp outboard motor on it im not sure of the year. it appears that it isnt the orignal motor form the boat which is an 82. well anyways... i have been doing some research about the motor(which fires right up when the key is turned) and found that this motor orignaly had an oil injection pump on it (VRO pump) but now it dosent. it seems to have been replaced with a regular pump. when i bought this boat the man i bought it from seaid to put one pint of oil for 6 gallons of gasoline. is this the correct mixture for this motor?<br /><br />thanks<br />-chris
Walker
Re: Johnson vro 200hp question
Nope, 1 pint per 6 gallons is the correct mix. 50:1
Cadones
thats what i meant to say 1 pint for 6 gallons, but thank you for the help
