johnson vro90 short to long conversion
cat5cable
hi all i have a jonny vro90 short/s and need it to be long do i have to look for another 90 or are other engines compatable?? ie 75 100 or 115hp engines, also anyone in the UK got an old jonny vro90 let me know
many thanks
tim
tashasdaddy
Re: johnson vro90 short to long conversion
what year. there are conversions, among the things that have to change are, driveshaft, water tube, shift linkage. the housing extention. and others.
cat5cable
its a 1986 but i have just measured from transom bracket to cavitation plate and its about 20 or 21 inchs would this be a long shaft.
But the transom on the boat is 23 inchs so would i need a longer shaft engine do they make longer than a long shaft ?
thanks
tim
Chinewalker
Are you measuring vertically or along the flat of the transom? You should be measuring vertically from the plane of the transom top to the plane of the boat bottom. For the motor you should be measuring from the plane of the clamp top (where it meets the transom top) to the plane of the anti-ventilation plate...
Easiest way to make your motor an X-long shaft is to find a blown XL model. Otherwise you'll be hunting around for bits and pieces...
- Scott
Dhadley
With a decent prop you're going to be fine. Most so called 20" transoms are about 20 3/4" anyway. And then the motor gets raised up a hole or two. If you get a 25" midsection you'll need a jackplate to raise it up high enough.
You're cleared to go boating.
cat5cable
yes measured like you said, and seems engine is still to short, when boat is used it it performs great until you go for top speed or wot, upto 5500rpm its ok but push it to 6500 engine revs out and boat goes no faster.
thanks
#tim
:D
tashasdaddy
you are over reving that engine. manual state full throttle operating range 4500-5500 power rated at 5000. don't ***** when it throws a rod at 6500.
as Dhadley said propped right you'll be fine.
cat5cable
many thanks for all help, i will try to find a decent prop.
thanks tim
Dhadley
check you tach setting. It's not likely you're getting to 6500 that easy with stock reeds. Make sure the tach is set on position 6 not 4.
